Hi
How can I add custom field to issue view in Details
Hello @Juhaina Almama
Is not possible out of the box, you can't change the view detail section
System fields on View Issue screen — System fields on the default 'View Issue' screen (e.g. Summary, Security Level, Issue Type, etc.) are fixed. This means that they will always appear in the same place on the 'View Issue' screen, even if you configure the Screen to move them onto a separate tab. Custom fields of related to Dates and People will also appear in their fixed section of the view issue screen.
https://confluence.atlassian.com/adminjiraserver073/defining-a-screen-861253436.html
I will wait, may someone knows ADD-on or someway to do this
