How to add a dependent drop down field?
nirmala December 17, 2018
Hi team,
Please help me with the steps on how to add a dependent drop down fields. example: Based on the category selected, I should be able to display the request type field.
Nirmala N
Tushar
Hi Nirmala,
You can use behaviour plugin for your requirement. Following is the sample code:
FormField fieldFF = getFieldByName("YOUR CUSTOM FIELD NAME HERE");
String fieldValue = fieldFF.getValue();
if("FIELD VALUE".equals(fieldValue)){
   FormField fieldToHideFF = getFieldByName("YOUR FIELD NAME HERE");
   fieldToHideFF.setHidden(true);
nirmala December 18, 2018
Thank you for the information.
Please elaborate on the steps to update the code.
nirmala December 24, 2018
Go to Customer Field-- Add List with "Select List (Casecading)", enter the valus for Parent field and then add value for the dependent fields
