How to add a project version state?
Dušan Juhás November 7, 2013
Is it possible to add a new project version state?
By default, it is possible to have a version in following states:
  • unreleased
  • released
  • released and built
  • archived
Is it possible to add a new state - in test?
How?
Nic Brough -Adaptavist-
November 7, 2013
Code.
You'll need to amend the core functionality in Jira to support this.
Deleted user November 17, 2013
Are there any resources you can point us to on how to approach this? I will be needing to do this as well.
November 17, 2013
I'm not that sure where to start really. I know you'll need to unpick the code that provides the version functionality so you can override/extend it, and think through how your changes affect the grouping in the version field drop-down lists.
If you've got a copy of the code for Jira (Commercial licencees have access) then that is where to start.
Pete P
January 29, 2018
We would also like to add a few extra states to our versions. Has there been any progress on this front since 2013?
January 29, 2018
Nope, there's no appetite to do this from what I've read here and on JaC
Ricardo Martinez
Is there any update on this matter?
Was anyone able to add a new Version Status?
Thanks in advance
