I am trying to connect to our hosted JIRA/Bamboo server which uses a certificate that is signed by an internal trusted CA (and an intermediate). This is in the Windows trust store and I have also added it to the IntelliJ accepted certificates (in fact I added all 3 for good measure). However, no matter what I do the certificate validation fails.
Is this a bug or is there something I haven't done right?
Here is the stack trace:
com.atlassian.theplugin.commons.remoteapi.RemoteApiLoginException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at com.atlassian.theplugin.commons.bamboo.api.LoginBambooSession.login(LoginBambooSession.java:130) at com.atlassian.theplugin.commons.bamboo.BambooServerFacadeImpl.testServerConnection(BambooServerFacadeImpl.java:99) at com.atlassian.connector.intellij.bamboo.IntelliJBambooServerFacade.testServerConnection(IntelliJBambooServerFacade.java:225) at com.atlassian.theplugin.idea.config.serverconfig.ProductConnector.connect(ProductConnector.java:35) at com.atlassian.theplugin.ConnectionWrapper.run(ConnectionWrapper.java:63) Caused by: com.atlassian.theplugin.commons.remoteapi.RemoteApiException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at com.atlassian.theplugin.commons.remoteapi.rest.AbstractHttpSession.retrievePostResponseInternalImpl(AbstractHttpSession.java:512) at com.atlassian.theplugin.commons.bamboo.api.LoginBambooSession.login(LoginBambooSession.java:94) ... 4 more Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949) at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302) at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296) at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1506) at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216) at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979) at sun.security.ssl.Handshaker.process_record(Handshaker.java:914) at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062) at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375) at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:747) at sun.security.ssl.AppOutputStream.write(AppOutputStream.java:123) at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82) at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140) at shadow.org.apache.commons.httpclient.methods.EntityEnclosingMethod.writeRequestBody(EntityEnclosingMethod.java:506) at shadow.org.apache.commons.httpclient.HttpMethodBase.writeRequest(HttpMethodBase.java:2114) at shadow.org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1096) at shadow.org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398) at shadow.org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at shadow.org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at shadow.org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323) at com.atlassian.theplugin.commons.remoteapi.rest.AbstractHttpSession.retrievePostResponseInternalImpl(AbstractHttpSession.java:436) ... 5 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387) at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292) at sun.security.validator.Validator.validate(Validator.java:260) at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:105) at com.atlassian.theplugin.commons.ssl.ConnectorTrustManager.checkServerTrusted(ConnectorTrustManager.java:92) at sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(SSLContextImpl.java:922) at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1488) ... 22 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:146) at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:131) at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382) ... 30 more
Did you find an answer for this?
I think I've encountered a similar issue.
Adding the certificate to the cacerts of the JRE Intellij uses allows access to the customly signed site.
are you sure you mean cacerts or you wanted to say keystore ?
I'm beginning to think that this doesn't support HTTPS at all. I can't see anywhere where it is setting the SSL context for the HTTPClient, in fact it seems that the version of HTTPClient that is used does not even have this method.
Apache HTTPClient references:
