How to add (append) user in multiuser picker field using jira-python libraries?
Teja
May 11, 2021 edited
Hi Team,
Need help to add a user to the existing multiuser picker field without replacing the original user.
Here is the jira-python code
for issue in jira.search_issues('project = "Abcd" and issuetype = Epic and status not in (Closed) and Testers in (tnaik)', maxResults=200):
print('{}: {}'.format(issue.key, issue.fields.customfield_10600)) //customfield_10600 Testers (multiuser field)
issue.update(fields={"customfield_10600": [ {"name": "tnaik1" }]})
I would like to append tnaik1 where the tnaik exist in the above JQL, Testers field.
The above script completely replaces the user.
Any help would be appreciated.
Warm Regards
Tejas
Prince Nyeche
May 11, 2021
You will need to get the accountId for any user picker field, then you can append that. That will involve you searching for the users from your user base.
Teja
May 11, 2021
Hi @Prince Nyeche
accountID? where do I need to get from?
Is this accountID related from Active Directory?
Teja
May 11, 2021
This is for Jira server.
Prince Nyeche
May 11, 2021
Hi @Teja
Sorry, didn't see the server tags. You don't need accountId if it's server. I believe the  approach I would use here is retrieve the current custom field value in a list, then create a payload that contains the old value and new value, then update the custom field with both values.
 issue.update(fields={"customfield_10600": [ {"name": "tnaik" }, {"name": "tnaik1" }]})
Teja
May 11, 2021
@Prince Nyeche
Ah-ha!
Here is the problem,
The Testers field contains other users with tnaik.
In this case, I need to append tnaik1.
Teja
May 19, 2021
@Prince Nyeche
Can you help me on this
Prince Nyeche
May 19, 2021 edited
Hey @Teja
I will start by get the current issue value. There's this library I wrote called jiraone you can use. Get it by using pip install jiraone.
from jiraone import LOGIN, endpoint, field
user = "username"
password = "password"
link = "https://yourinstance.jira.com"
LOGIN(user=user, password=password, url=link)
keys = "COM-42"
name = "Multiple-User" # custom field name
LOGIN.api = False
issues = LOGIN.get(endpoint.issues(keys)).json()
fields = field.get_field(name).get("id")
value = issues["fields"][fields]
The value will be a list of the current users in the multi user picker field. Then you can append a new value by doing
value.append({"name": "tnaik1"})
issue.update(fields={"customfield_10600": value})
Just to add in, since you're using jira-python library, you just need to get the same login you use to authenticate it and pass it to the LOGIN() variable rather than define a new one.
Like Teja likes this
Teja
May 20, 2021
@Prince Nyeche
Correct me, if am doing wrong,
Installed pip install jiraone
then
Wrote the code in my sublime and saved it
user = "tnaik"
password = "xyz123"
link = "https://jiratest.atlassian.info/"
keys = "ATL-32277"
name = "Testers" # custom field name
LOGIN.api = False
and while trying to run >> python jiratest2.py
Getting Error Like This:
C:\D Drive\Python Practice>python Jiratest2.py
Traceback (most recent call last):
File "Jiratest2.py", line 11, in <module>
File "C:\Python\Python38-32\lib\site-packages\requests\models.py", line 898, in json
return complexjson.loads(self.text, **kwargs)
File "C:\Python\Python38-32\lib\json\__init__.py", line 357, in loads
return _default_decoder.decode(s)
File "C:\Python\Python38-32\lib\json\decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Python\Python38-32\lib\json\decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Anything wrong?
Prince_Service_Rocket May 20, 2021
can you remove the "/" from the  link?
Teja
May 21, 2021
Hi @Prince_Service_Rocket ( @Prince Nyeche )
I guess I found another issue, below block shows the error:
C:\D Drive\Python Practice>python jiratest2.py
File "jiratest2.py", line 12, in <module>
File "C:\Python\Python38-32\lib\site-packages\jiraone\access.py", line 1424, in get_field
"name": a["name"], "id": a["id"], "key": a["key"],
KeyError: 'key'
Prince Nyeche
May 21, 2021
Hey @Teja
The error is saying that the name "key" is not in the payload. Please can you change that line from
to
fields = field.search_field(name).get("id")
This methods searches for custom fields specifically and doesn't have a "key" name. I don't have a server instance to confirm this but given that Jira is basically the same software across different platform (server or cloud) the response should be similar.
Teja
May 21, 2021
@Prince Nyeche
No luck still getting an errors
File "C:\Python\Python38-32\lib\site-packages\jiraone\access.py", line 1393, in search_field
data = load.json()
Teja
May 21, 2021
I was able to append label by using this code
issue.fields.labels.append(u'bla')
issue.update(fields={'labels': issue.fields.labels})
but not sure why I am not able to append user
issue.fields.labels and issue.fields.customfield_10600 are same type class 'list'
Prince Nyeche
May 21, 2021
It pretty tricky to debug without knowing what payload comes through with the below
 Also with this issue.fields.customfield_10600 what is the output you receive. Can you show a sample?
Teja
May 21, 2021
Ok.
issue.fields.customfield_10600.append({"name": "tnaik`"})
issue.update(fields={"customfield_10600": issue.fields.customfield_10600})
The output
File "jiratest1.py", line 37, in <module>
File "C:\Python\Python38-32\lib\site-packages\jira\resources.py", line 485, in update
super(Issue, self).update(async_=async_, jira=jira, notify=notify, fields=data)
File "C:\Python\Python38-32\lib\site-packages\jira\resources.py", line 225, in update
data = json.dumps(data)
File "C:\Python\Python38-32\lib\json\__init__.py", line 231, in dumps
return _default_encoder.encode(obj)
File "C:\Python\Python38-32\lib\json\encoder.py", line 199, in encode
chunks = self.iterencode(o, _one_shot=True)
File "C:\Python\Python38-32\lib\json\encoder.py", line 257, in iterencode
return _iterencode(o, 0)
File "C:\Python\Python38-32\lib\json\encoder.py", line 179, in default
raise TypeError(f'Object of type {o.__class__.__name__} '
TypeError: Object of type User is not JSON serializable
Prince Nyeche
May 21, 2021
@Teja
I meant if you could do a print() of issue.fields.customfield_10600 after the append? I want to see the result of that.
Teja
May 21, 2021
Ok,
print(issue.fields.customfield_10600)
#issue.update(fields={"customfield_10600": issue.fields.customfield_10600})
Output:
[<JIRA User: displayName='ravi.kapoor@gtnexus.com', key='rkapoor', name='rkapoor'>, {'name': 'tnaik`'}]
rkapoor already in the Testers field
Teja
May 21, 2021
@Prince Nyeche
When I use jira.user to append it
testuser = jira.user('tnaik')
issue.fields.customfield_10600.append(testuser)
The output seems ok, but issue.update was still throwing an error
print()
[<JIRA User: displayName='ravi.kapoor@gtnexus.com', key='rkapoor', name='rkapoor'>, <JIRA User: displayName='Teju Naik', key='tnaik', name='tnaik'>]
File "jiratest1.py", line 38, in <module>
Prince Nyeche
May 21, 2021
 @Teja  please mask your email address. I think the payload might be the problem. You're getting a list but the representation isn't what the issue.update is expecting. You need to get the values in a List[Dict], please can you also print() the value of fields let me see it's value?
Teja
May 21, 2021
Hi @Prince Nyeche
Here is my email address tejusn5@gmail.com
And the print of this code is
SS:
Prince Nyeche
May 21, 2021
Hey @Teja
Can you try this code and let me know what's the value it prints out
keys = "GTN-32231"
name = "Testers"
# get field
fields = LOGIN.get("{}/rest/api/2/field".format(LOGIN.base_url)).json()
def rerun():
for z in list(fields):
if name in z["name"]:
return z
d = rerun().get("id")
value: list = issues["fields"][d]
print(value)
Teja
May 21, 2021 edited
Hi @Prince Nyeche
Some error:
File "jiratest2.py", line 21, in <module>
Prince Nyeche
May 21, 2021
Do the below please and let me know
LOGIN.api = False
keys = "GTN-32231"
name = "Testers"
# get field
def rerun():
return z
print(value)
Prince Nyeche
May 21, 2021
@Teja  Please hide any credentials or remove the image you just posted.
Teja
May 21, 2021
Thanks I forgot to scratch credentials
Prince Nyeche
May 21, 2021
Let me know the output of my previous comment.
LOGIN.api = False
keys = "GTN-32231"
name = "Testers"
# get field
def rerun():
return z
print(value)
Prince Nyeche
May 21, 2021 edited
user = "username"
LOGIN.api = False
keys = "GTN-32231"
name = "Testers"
# get field
def rerun():
return z
print(value)
@Tejaplease ignore my previous comment try the above code as shown and let me know if the output is shown to you. The reason it didn't work before was because on Jira server the endpoint has to be "/rest/api/2" or "/rest/api/latest". The LOGIN.api = False changes that context to latest and has to be called before the login is initiated. That's why the error in JSON always returned "None" denoting that it can't get the right output.
Teja
May 21, 2021
@Prince Nyeche
Console output:
[{'self': 'https://jiratest.xxx.info/rest/api/2/user?username=test-qa', 'name': 'test-qa', 'key': 'test-qa', 'emailAddress': 'test@abcd.com', 'avatarUrls': {'48x48': 'https://www.gravatar.com/avatar/7c904adb430b791c0abd432442374b17?d=mm&s=48', '24x24': 'https://www.gravatar.com/avatar/7c904adb430b791c0abd432442374b17?d=mm&s=24', '16x16': 'https://www.gravatar.com/avatar/7c904adb430b791c0abd432442374b17?d=mm&s=16', '32x32': 'https://www.gravatar.com/avatar/7c904adb430b791c0abd432442374b17?d=mm&s=32'}, 'displayName': 'Test QA User', 'active': True, 'timeZone': 'UTC'}]
Testers field ss:
Prince Nyeche
May 21, 2021
Okay! That's the payload you need. Now just do the append as before and ensure you add the import from jira-python so you can update the issue (if using that route). otherwise another method you could use to update the issue is
# previous statements
# payload to post to edit issue endpoint
data = {
"fields": {d: value}
execute = LOGIN.put
(endpoint.issues(keys), payload=data)
print(execute) # should return a type - Response
Hope this helps.
Cheers
Teja
May 21, 2021
@Prince Nyeche
Voila! that's awesome.
I need you're another favor that I need to execute by JQL
for issue in jira.search_issues('project = "xyz" and issuetype = Epic and status not in (Closed) and Testers in (tnaik)', maxResults=100):
Where do I need to put the JQL, instead of single issue key?
Prince Nyeche
May 21, 2021
# previous import statement
import json
user = "username" password = "password" link = "https://yourinstance.jira.com"
LOGIN.api = False
jql = "project = 'xyz' and issuetype = Epic and status not in (Closed) and Testers in (tnaik)"
count = 0
while True:
load = LOGIN.get(endpoint.search_issues_jql(query=jql, start_at=count))
if load.status_code < 300:
jira_issue = json.loads(load.content)
if count > jira_issue["total"]:
break
for issue in jira_issue["issues"]:
keys = issue["key"]
name = "Testers"
# other statements goes here.
count += 50
The thing here is that your entire issues will be wrapped in the for loop. So you can do more things from there
Teja
May 24, 2021
It worked. That's really great @Prince Nyeche .
Prince Nyeche
May 24, 2021
Great to hear that @Teja Please accept the answer if the solution answers your question. So other users can use a similar solution.
Teja
May 25, 2021
Hi @Prince Nyeche
I found a simple way to append user to the multiuser field using jira-python library.
testuser = jira.user('tnaik1')
testlist = issue.fields.customfield_10600
testlist.append(testuser)
new_assignees = [{"name": str(u.name)} for u in testlist]
issue.update(fields={"customfield_10600": new_assignees})
Like Prince Nyeche likes this
Prince Nyeche
May 25, 2021
That's great to hear @Teja .The simpler the better.
Register now
