I would like to configure the test details section a bit.
Right now there are three columns "Test Step", "Test Data" and "Expected Result". I would like to add a further column and / or change the name of a column.
Is that possible?
Hello @codecentric,
It is currently not possible to Add/Edit the Test Detail columns.
We from Zephyr Support submitted a feature request for this case. It is submitted under FR-445. Adding a feature request to our system means we acknowledge that it is a feature that does not exist in our system and that it has been added to the pipeline for consideration.
If anybody would like to know the status of the feature request. Please open a support request by accessing the below link along with this feature request ID. We will check and provide you the latest updates with regards to this feature request.
https://support.getzephyr.com/ (you will need to sign up here and use the option "Submit a Case").
Thanks & Regards,
Zephyr Support
Read the story
