Hello All,
Is it possible to add a default value in Jira Text Custom Field using Behaviours or adding javascript in Description?
Manikanta.
Hi @Bunty,
Why you need to use script or other plugin. you can set default value in custom field configuration directly
it really doesn't work as Edit Default Value for multi line text box.
Hi @Bunty,
Yes it is possible with behaviors. select the Add field as Description and add a server script
