How to add fixed text in comment on transition using Script runner post function
Lotus Support October 16, 2017
I would like to add fixed text to user comment..For example when user press "cancel" button (on transition in workflow), i would like to run custom script runnner code that is going to add prefix - word "Cancel" - before the user comment.
When user cliked on Cancel - custom screen opened with requirmenet to enter reason for cancel, and comment...
Code that i am using is:
def commentManager = ComponentAccessor.getCommentManager()
def user = ComponentAccessor.getJiraAuthenticationContext().getUser()
commentManager.create(
issue,
user,
"CANCELLED",
false)
But the problem is that on transition  i now have two lines in comments:
xxxxx yyyyyyy added a comment - 5 minutes ago
CANCELLED
xxxxx yyyyyy  added a comment - 5 minutes ago
We decided to cancel issue
I would like to have just one line:
CANCELLED - We decided to cancel issue
I tried this code that works similar
Issue issue = issue
// Get the comment, the user added in the form
def originalComment = transientVars.comment as String
// Concat to the original comment, ours. Use \n for a new line
def comment = "-CANCELLED-" + originalComment
commentManager.create(issue, user, comment, true)
But i am getting also two lines in comment - one with customer entered text, and other with prefix
-CANCELLED-
-CANCELED- We decided to cancel issue
