How to add labels to Jira via Rest API
Devi Foskett February 1, 2019 edited
I would like to be able to add labels to a Jira using rest apis. I am using javascript currently to create an issue. I do not know the json required to create the label and need help figuring that out. I use only javascript and json for this thank you! When using postman there is a 415 error when I add "Labels":["Test"] to create a label.
Javascript:
var xhr = new XMLHttpRequest();
xhr.open(method, url);
xhr.setRequestHeader("Content-Type","application/json");
labels = ' {"fields": { "project": { "key": "'+ projectKey +'" }, "labels":["sd_reviewed", "ta_reviewed", "Reviewed", "Functional"]}} ';
xhr.onreadystatechange = function() {
if (xhr.readyState === 4 && xhr.status == 200) {
console.log(xhr.responseText);
xhr.send(labels);
Alin_Gabriel_Draghici May 1, 2020
Reposting cause my edit dissapeared (?)
Endpoint: https://YourJiraInstance.com/rest/api/2/issue/issue-id-right-here
Body: {"update":{"labels":[{"add":"this-is-the-label-you're-adding"}]}}
POST method, basic AUTH
Cristina Donaldson
January 28, 2022
Thanks, this was very helpful!
Rusty Czerwinski
January 2, 2023
Works with this payload, using PUT method as Warren mentions below..  Thanks!
Like Richard Cross likes this
Andrew Januszak
Per REST API Doc (https://docs.atlassian.com/software/jira/docs/api/REST/8.22.4/#issue-editIssue) the syntax is:
"labels":[{"add":"triaged"},{"remove":"blocker"}]}
In your case, I believe it would be:
"labels":[{"add":"sd_reviewed", "ta_reviewed", "Reviewed", "Functional"}]
Tomer Ben Arye March 13, 2024
nope...
This one works:
{ "update": { "labels": [ { "add": "lable1" }, { "add": "label2" } ] } }
Like Daniel Eads likes this
Tomer Ben Arye March 13, 2024 edited
PUT method.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-issueidorkey-put
/rest/api/3/issue/{issueIdOrKey}
"update": {
"labels": [
"add": "bump1"
"add": "no_sf_case_id"
Fadi Hawli
As of now I thought the only way you can create labels is by passing the issue key and then adding a label against the issue key. If you do not use an issue the api will not work. Has anyone solved this by being able to create labels without reference to an issue key?
Tomer Ben Arye August 8, 2024
But I gave you the option to enter KEY or ID...
Roman Wolf
March 11, 2025 edited
Hi @Fadi Hawli ,
as per my understanding the label concept in JIRA is different from what you expect.
You expect labels to be an independent entity in JIRA, like components or versions.
In fact labels just exist as an attribute of an issue. When you remove a label from all the issues the label is gone and cannot be found anywhere.
That explains why it is mandatory to provide an issue key.
Hope this helps, Roman
Warren
February 1, 2019
Hi @Devi Foskett
Within the JSON, this is the format of adding a label
 "labels": [
"Testing"
Hope this helps you
In postman this will return a 415 error and not work.
@Warren I have tried the code mentioned above with no avail. If you would like to see code to better understand what I am trying to accomplish I can add it above.
Warren
February 1, 2019
Are you trying to
  1. create an issue and set the label at the same time? If so, you're missing the issuetype. You also need to pass in values for EVERY mandatory field
  2. add a label to an existing issue?
What error do you get using your javascript?
Below is what my JSON looks like to create an issue and set it's label
"fields": {
"project": {
"key": "DS"
"summary": "Post Refresh work",
"issuetype": {
"name": "Task"
"labels": [
"Label1",
"Label2"
@Warren I am trying to add labels to an existing project. With the code you provided I get a status error 400.
Warren
February 1, 2019
If you look at this you'll see you need to do a PUT if you're updating an existing issue. Is that what you've been using?
@Warren No I have not I will try that!
I am getting returned a status error 405 now.
Like Fianna O'Brien likes this
Get Certified! ✍️
