×I want to add multiple IF conditions in Jira automation rule.
For example, if the linked task to current task is done as well as current task is done, then do A.
How do I do that?
Hi Lady,
If you use the IF/ELSE Condition, then you can add multiple conditions in a single step - using OR functionality or AND functionality. And, of course, you can have separate IF conditions in that thread if you like. You don't HAVE to have something in the ELSE step.
Hi @Jar Lady
Welcome to our Community.
I think you could try if:matches condition as follows:
Please Note: it's in Cloud environment. If your version of Server is low, maybe you won't find it out.
Hope it helps you.
YY哥
