How to add parent's key to summary of a child?
Eric C March 21, 2024 edited
In our daily talks, we refer quite a lot to that "ABCDE-45678" ticket, and that "GHJKL-87654" ticket.
It would help us a lot to have the parent's Key at the start of a Child's summary, eg "ABCDE-45678, do this and that".
I've managed with an automation that is adding - at creation - that Key to the summary, but can't figure out 1) how to keep?/add?/concatenate? ...the original text "do this and that" and 2) add extra ", " in between. Any suggestion? Or a better solution, than automation?
Final result should look like
{{issue.parent.key}} + ", " + {{issue.summary}}
Tugba Capaci
March 21, 2024
Hi @Eric C
The correct syntax is:
{{issue.parent.key}}, {{issue.summary}}
You can use this directly.
You don't need to add  + " "+
Tugba
actioner.com
Why complicate things..... :D
Like Tugba Capaci likes this
Karan Sharma
June 3, 2024
Hey @Eric C
Any chance you could post the complete script here? I have a similar use case and feel your script could help me.
