×Hi Kartik,
The regex validator is present in Jira Cloud as a built-in feature.
You can check
Anzar Khan
"Regex Validator- This validator enables to match a custom field value by regex."
This is the exact validator that we want in cloud. Is this available or is there any workaround ?
Hi @Kartik Pant ,
Yes, as @Anzar said, that exact validator is available in every Jira Cloud instance.
Best regards,
Oliver
Hi Kartik,
If this answers your question, Can you accept the answer so the community can also get help from the same.
Thanks Oliver for adding value. Appreciated.
Anzar
Hi @Kartik Pant ,
Welcome to the community!
Just adding to @Anzar's correct answer here… There is indeed a regex validator available, but there is no such condition built-in.
What I typically recommend admins migrating from server is to look at one of the many Workflow Apps available on the marketplace, because virtually all of them support Jira Expressions.
In short, Jira Expressions allow you to write a complex condition or validator using simple, concise statements such as:
// Has the current user added a comment to the issue?
issue.comments
.filter(c => c.author.accountId == user.accountId)
.length > 0
Jira Expression can do an amazing amount of things, just check the reference!
I'll end my rave about this feature with a recommendation for my favorite workflow app, Cloud Workflows, but it's a biased recommendation as I was heavily involved in the development.
Anyway, hope that helps, Jira Expressions are awesome!
Oliver
