How to add the + button? how to create epics within an initiative
Emily Triyonis
How come we can create sub tasks in the view screen of an Epic (because there is that + button for Child Issues) but the + button doesnt exist on an Initiative view screen so we can create Epics right then and there?
Walter Buggenhout
@Vijay Sv , @Emily Triyonis ,
There is no way to add a "+" to your initiatives for child issues. But there are several workarounds:
  • Create Epics under your initiatives in the Portfolio for Jira app rather than directly in your Jira issues;
  • Also in Portfolio for Jira: use drag and drop or bulk edit functionality to associate unlinked Epics with their parent initiatives;
  • Or the other way around: include the parent field on your Create Epic screen so you can enter the desired initiative when creating the Epic issue.
Vijay Sv
@Emily Triyonis , I have a similar requirement. Did you figure out a way to add "+" to add "Epics"
Walter Buggenhout
Epics are a specific issue type that have this create issue in epic feature. It comes with JIRA Software and adds e.g. the ability to filter your backlog by them on a scrum board. Standard issue types - such as initiatives - do not have this feature.
When using JIRA out of the box, you can use issue linking to reproduce similar behaviour. On an issue, under More (...) select 'create and link' issue. When complete, you will see the related epics of your initiative listed on the Initiative's detail view and have a + button available to add more. Note, however, that this does not enable some of the specific additional features of epics.
Register today
