Hi Team,
In my project i have added the filed type as Number filed so that it's displaying the float value
(i.e 123.0),But we require custom filed as a integer value(i.e 123).
Please help me out how to add the field type as integer in Jira 6.1
Shankar.chintala.
You need a new custom field type to do that.
The built-in "number" field is a floating point and it can't be changed.
Hi Nic,
Thanks for quick reply,How to add the new custom field type as integer.
Shankar.chintala.
You'll need to find or write an addon to do it.
