How to additionally control the bug process
wenjing_w_j_liang_sp September 26, 2021
At present, all issues in my workflow share the same process. After changing one of them, all issues have been changed. Now I want to customize a process specifically for issue bugs.
Julia Shcherbyna _SaaSJet_
Hi @wenjing_w_j_liang_sp
You can also try add-on BPM (Business Process Manager), developed by my team to create and control the bug process.
It allows:
  • create a process template with all the steps required to complete;
  • add the form needed to submit, instructions, checklists, assignees, issue type, and project to each step of the process;
  • run a template in one click;
  • monitor all active processes;
Also, you can set up a scheduled process.
Hope it helps.
Regard,
Julia
srikanth u
Yes, you can.
  1. Go to the Issues -> Workflows.
  2. Select Add workflow/Import from Marketplace.
  3. Now Edit the newly created workflow by clicking the edit icon besides to the newly created workflow.
  4. Add the Statuses and transitions as per your wish and publish the workflow.
  5. Now go the corresponding Project Settings -> Workflows.
  6. Edit the Bug workflow and select the newly created workflows.
  7. Done!
Please accept if it resolves your problem.
Register today
