I have create Workflow but I don't know how to add projects to workflow Schemes (Assigned Schemes).
Anyone know and help me??
Here is a video I took: http://screencast.com/t/yZVaafBqi
Chi
Regards
Chander Inguva
The screens your mention are completely impossible to find for me. On project settings, I only have name, key and access. and the possibility to delete the project.
No workflow tab available, and even not when creating a project : I can select form a number of templates (Scrum, Kanban, ....) but I cannot select my workflow.
When defining a workflow scheme, I see no way at assign that scheme to a project ...
Totally lost, it seems I can only do pretty standard stuff. I find the interface for setting up such customisations in JIRA far from intuitive ..
Jira reworked UI and ignored to update the documentation. The screen is either 1) hidden and there's no button for it 2) removed
Not sure what to think about it...
Same here, I can't assign a workflow to my projects and the documentation with the new and imposed UI are not updated, so there is no way to do it following the documentation.
If at least I could work with the old UI...
Just create a project with standard type, not those fancy undocumented agile types
@James Campbell No, sorry... I'm trying to work with server now and solve everything.
@Gitlab User I just want a simple kanban with my own workflow adding an in-review state. Your solution is "don't use what you are paying for". That would never be a solution at all.
There is no option to create a classic project for me. It seems the very first user as jira admin was able to do ONLY the first project. Now he neither can.
Atlassian!!!!
Chander,
I am new to Jira.
I have created the workflow, but on the Project tab, I could not find the Workflow button as you suggested.
I am a site administrator for my project page.
Do you have any advice on how to fix that?
Jing
Hey,
don't get me wrong but have you ever had a look a the documentation?
This will get you started creating a workflow:
https://confluence.atlassian.com/display/JIRA/Configuring+Workflow
Then you create a workflow scheme and associate workflows (activate them) with that scheme:
https://confluence.atlassian.com/display/JIRACLOUD/Activating+workflow
Here you'll find more info on schemes:
https://confluence.atlassian.com/display/JIRA/Configuring+workflow+schemes
Hope that help,
Christian
yes, I did it ok yesterday as many time to find out on document but it works ok now. Thanks for you help. Do you have Skype too? Regards, Chi
The documentation is scattered everywhere and usually not helpful. Something as simple as changing a Workflow, Screen or Permission Scheme can be quite challenging.
Don't get me wrong, Jira is a great product once configured, but the documentation and support are pitiful at best!
Those links are all OK, but none of them answers the original question: once you have created a Workflow, assigned it to a Workflow Scheme, how do you assign the workflow scheme to a project?
I have quite a lot of experience with the old Jira UI, fully understand the concepts, but simply can't find the way to do this.
i have the same problem
OK, this is so very stupid that I have overslipped at least 3x of the correct answer. It is indeed here: https://confluence.atlassian.com/adminjiracloud/managing-your-workflows-776636587.html
Once you've already created your inactive workflow (that you can view under Projects - Workflows (inactive workflows are hid in a section under active ones)), go to Issues - Workflows.
Select the workflow scheme that you want to associate the new workflow with and click Edit.
Here click the Add workflow button, select Add exisiting, and you will see all the inactive workflows listed there. Select it, assign all issue types you want to to this workflow. Then you can publish the draft workflow.
For publishing you need to map the old statuses to the new ones to ensure that no issue is left out. Once you are done with this, click Associate at the bottom of the page. It will then migrate all issues to the new workflow.
Looks like nobody cares at atlassian. Except asking to subscribe to a higher plan, I don't see any help from the company. Documentation not clear, not up to date...
I am facing the same problem and couldn't figure out a solution to this. Did anyone get a solution?
This page is fundamentally misleading and out of date although I eventually found the answer in Settings -> Workflows -> Switch Scheme:
https://confluence.atlassian.com/adminjiracloud/working-with-workflows-776636540.html
It is this section:
To finish activating your workflow, associate the workflow scheme it's in with a project (if an issue type is not defined in the project's issue type scheme, that specific workflow is not used):
In the sidebar, click Issue type schemes. You'll see which workflow scheme the project currently uses.
Click Associate to begin the migration process. Each issue needs to have a valid status, so you may need to assign statuses to a select number of issues after you switch workflow schemes.
Paul,
I am new to Jira.
We have created the workflow scheme. But there is no workflow button under Project.
I am the site admin. Do you know what might have caused the problem?
Thanks a lot
Jing
i have the same problem and cannot fix it
Nope.
1) Workflows missing from the Project Settings
2) Tried a new Workflow and adding a project to it but WHERE IS THAT FUNCTIONALITY? WHERE IN THE WORLD?
