As the titile says. Issue has two CFs, CF A CF B. What I want is that when user excute a transition it popup a screen, in the screen, the CF B will auto filled with the value of CF A. And user can also change the CF B's value as he want.
How to do this?
I know how to set CF B's value as CF A's by using script runner in workfolw postfunction. But I want it auto fill in the screen.
Thanks very much!
Hi Xinan,
Have you attempted to use this plugin instead to see if it has the functionality you are looking for? https://marketplace.atlassian.com/plugins/com.innovalog.jmcf.jira-misc-custom-fields
