How to auto populate the values ​​of custom fields based on another custom field value selected?
Lender
November 25, 2020 edited
I need to know if there is possible to automatically populate custom fields (Select List - single choice),  based on a previous field value selected (Select List - single choice).
Remark: Each field has default values and ordered options.
For example:* The custom field "Document" has the options:
- 1
- 2
- 3.
* The custom field "Area" has the options:
- Marketing
- Administration
- Financial.
* The custom field "Execution Priority" has the options:
- Normal
- Critical
- Low.
*** If I select the FIRST VALUE in the "Document" custom field, the other fields should automatically select the FIRST value:
- Area: Marketing
- Execution Priority: Normal.
*** If I select the SECOND VALUE in the "Document" custom field, the other fields should automatically select the SECOND value:
- Area: Administration
- Execution Priority: Critical.
*** If I select the THIRD VALUE in the "Document" custom field, the other fields should automatically select the THIRD value:
- Area: Financial
- Execution Priority: Low.
Can someone help me?
Thank you for your time.
Kind Regards
Szabolcs Kiss
December 6, 2020
Hi Leandro,
I think you need additional plugin installed (JMWE or Scriptrunner or...) and you can set a postfunction.
