How to auto update select list custom field(valueList) based on other custom field value selection?
Cheerla Vamsi Krishna
March 15, 2022
Hi Team,
I am trying to update select list custom field Value( List) based on other custom field value selection using listeners in scrip runner.
For Example: If i select Custom field A and the  Value is B Then Custom field C Value should be updated as D by using the Listeners in scrip runner.
Can any one help on the same.
CH Vamsi
March 18, 2022
Hi @Piyush A (STR)  I have used the below code to set the value in one of the custom field but not able to set. can you please help me on the same.
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.IssueManager
IssueManager im = ComponentAccessor.getIssueManager()
MutableIssue issue = im.getIssueObject("HSYS-5318")
if (issue){
//Get the value
def cField = customFieldManager.getCustomFieldObject("customfield_XXX")
def cFieldvalue = issue.getCustomFieldValue(cField)
if ( cFieldvalue != "Devices"){
def customFieldManagerPL = ComponentAccessor.getCustomFieldManager()
def cFieldPL = customFieldManagerPL.getCustomFieldObject("customfield_XXX")
def cFieldvaluePL = issue.getCustomFieldValue(cFieldPL)
log.warn("Current parent Link ---" + cFieldvaluePL)
final customFieldName = 'Parent Link'
final isu = 'HSYS-5318'
final newValue = 'SFLS-889 CC-ART: Tender Insights within Portfolio'
def issu = ComponentAccessor.issueManager.getIssueByCurrentKey(isu)
def customField = ComponentAccessor.customFieldManager.getCustomFieldObjects(issu).findByName(customFieldName)
def availableOptions = ComponentAccessor.optionsManager.getOptions(customField.getRelevantConfig(issu))
def optionToSet = availableOptions.find { it.value == newValue }
customField.updateValue(null, issu, new ModifiedValue(issue.getCustomFieldValue(customField), optionToSet), new DefaultIssueChangeHolder())
//cFieldvaluePL.updateValue(null, issue , new ModifiedValue(cFieldValue, 'Test'))
//cFieldPL.updateValue(null, issue, new ModifiedValue(cFieldvaluePL, "new DefaultIssueChangeHolder"))
//Update the Value
//def changeHolder = new DefaultIssueChangeHolder()
//cField.updateValue(null, issue new ModifiedValue(cFieldValue, "Test"))
log.warn("Portfolio value is ---- " +cFieldvalue)
}else {
return "Issue doesn't exist"
Piyush A (STR)
Hi @Cheerla Vamsi Krishna
Welcome to the community. !!
Add the below code to the listeners for Issue Update and Create. You may try to add new conditions or changes according to your needs.
// the name of the custom field (single select list type)
final customFieldNameA = 'Select List CF'
final customFieldNameB = 'Select List CF B'
// the value of the new option to set
final newValue = 'D'
final exValue = 'A'
Issue issue = event.issue
def issueKey = issue.key
log.warn(issueKey)
assert issue: "Could not find issue with key $issueKey"
def customFieldA = ComponentAccessor.customFieldManager.getCustomFieldObjects(issue).findByName(customFieldNameA)
assert customFieldA: "Could not find custom field with name $customFieldNameA"
def customFieldB = ComponentAccessor.customFieldManager.getCustomFieldObjects(issue).findByName(customFieldNameB)
assert customFieldB: "Could not find custom field with name $customFieldNameB"
if(issue.getCustomFieldValue(customFieldA).toString() == 'A' && issue.getCustomFieldValue(customFieldB) == null ){
def availableOptions = ComponentAccessor.optionsManager.getOptions(customFieldB.getRelevantConfig(issue))
assert optionToSet: "Could not find option with value $newValue. Available options are ${availableOptions*.value.join(",")}"
customFieldB.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(customFieldB), optionToSet), new DefaultIssueChangeHolder())
Also, on the create screen itself you can make the auto changes using Behaviour.
kiranmai_genkolla March 21, 2022
Hi @Piyush A (STR) ,
In my case the parent link in the portfolio custom field .. can any one help ime seting the value in this custom field .with REST API
Please help me in code for this
Piyush A (STR)
With Rest api? OR via the scriptrunner?
kiranmai_genkolla March 21, 2022 edited
script listner (with rest api in it)
Tansu Akdeniz
Do you have Automation for Jira add-on? If yes, you can simply define a rule for this scenario. For sure, it is possible via Script Runner. But you should be familiar with scripting. You can look at sample codes in community.
Also take a look at: https://scriptrunner.adaptavist.com/latest/jira/listeners.html
