I would like to get the Reporter added to the Watchers list on issue creation.
Likely this could be done with a small script and script runner plugin ... Jamie, could you help as you did in this question? ;) TNX!
BR, Markus
I should really start charging for my services ;-)
But as it happens, the latest version of the script runner has this available as a post-function or listener: https://studio.plugins.atlassian.com/wiki/display/GRV/Listeners#Listeners-AddWatcher
Two choices:
1. Add it as a post-function to the issue create event... you don't need a condition unless you want one.
2. Add it as a listener and select the "Issue Created" event and the relevant project(s).
I would go with choice (1).
cheers, jamie
Dear Jamie,
Right! I would not mind to pay for this prompt service! Spending my time trying to solve it might be more expensive! ;)
Thanks for your support here (in old forums and on your plugin page)!
Will try your listener...
BR,Markus
No problem ;-)
Learn more
