Hi everybody,
i am using scriptrunner built in script for creating subtask on transition.
I want to create a condition for avoiding the creation of the subtask if subtask with certain summary already exists.
I have tried several scripts on the condition field but it didn't work.
Any idea would be more than welcome.
Kostas
In the following example the issue won't be created if a sub-task that contains the same summary already exists.
You may customize that query to fit your needs.
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.search.SearchProvider import com.atlassian.jira.jql.builder.JqlQueryBuilder import com.opensymphony.workflow.InvalidInputException import examples.ContextBaseScript import groovy.transform.BaseScript // ALTERNATIVE CASE WITH PARSED JQL STRING // JqlQueryParser jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser.class) // Query query = jqlQueryParser.parseQuery("JQL QUERY STRING") def builder = JqlQueryBuilder.newClauseBuilder(); def query = builder .summary(issue.summary).and().issueTypeIsSubtask().buildQuery() def authContext = ComponentAccessor.getJiraAuthenticationContext() def searchProvider = ComponentAccessor.getComponent(SearchProvider.class) def user = authContext?.getUser() if (searchProvider.searchCount(query, user) != 0) { throw new InvalidInputException("The given summary description already exists") }
I tried to use this script to check if the summary from the same issuetype (not Subtask) already exist.
So in other words the summary should be unique. How would the scrip look like? Sorry I'm not familiar with Groovy.
Help us plant more trees
