How to block the edition for a custom field ?
Aurelie Pilette
I would like to create a custom field ==>  i know make that
But I would that this field must be edited only by the workflow.
i know how to fill this field by the workflow.
But I would like that when a user is editing the issue, this field mustn't be modified ==> how can i make that please ?
Orawan Sittakom
July 4, 2017
Hi Aurelie,
Do you mean, you need to block editing a custom field for all users or some users on Edit screen?
- If you mean blocking edition for all users, you can move this custom field out of Edit screen
- If you mean blocking editing for some users, JIRA doesn't provide this feature. Workaround: you can try Field Security Plug-in for JIRA
