How to bold the system\custom field name
Dan27
I would like to bold custom fields\system fields on create +edit screens of specific issues.
For example, priority system field. I would like to bold the name 'Priority'.
How can I do it?
Daniel
Orkun Gedik
November 5, 2018
Hi @Dan27,
@Yogesh Mude is right. Also, you can place a javascript code to make the labes bold into the AnnouncementBanner.
Dan27
ok @Orkun Gedik AnnouncementBanner looks like a good option.
Can you help me with the script? How to write it?
Andy Heinzer
November 5, 2018
Dan27
Thank you @Orkun Gedik @Andy Heinzer ,
Is it possible to add condition (issue type = story) to this script?
Bold the field only of Story type issue.
Daniel
Orkun Gedik
November 7, 2018
Hello @Dan27
Yes it is possible. You just need the check "Issue Type" custom field value in your javascript code as follows
if(document.getElementById("issuetype-field").value == "Story"){
Dan27
@Orkun Gedik , If I don't have the field 'issue type' in Edit screen, How can I get the value of the issue type ?
Yogesh Mude
November 5, 2018
HI @Dan27
This will not be done easily, you need to do the changes in Jira source code.
Dan27
Ok, How can I change the source code..?
Thulasiraman Nagarajan October 5, 2023
@Dan27 Did you find the source code to edit it?? 😂
