How to build and execute a JQL with parameters with scriptrunner
Tomas Arguinzones Yahoo
I need to build and execute a JQL in a script listener to search for certain words in the Description field in JIRA. For instance, once I obtained the values for param1, param2, and param3 (I know how to do the parsing), I need to build a JQL and excute it to search for all Jira issues where the description fields contains all three values, like this:
description ~ param1 AND description ~ param2 AND description ~ param3
Thank you for your assistance
Alexey Matveev
January 8, 2018
Hi Alexey...thank you so much for your assistance. This is really helpful. I am still struggling with this line of the code:
def query = jqlQueryParser.parseQuery("description ~ param1 AND description ~ param2 AND description ~ param3")
How do I specify that I need the JQL to execute with the value in param1/param2/param3 and not the words param1/param2/param3?
Thank you for your help
Alexey Matveev
January 8, 2018
You could write like this
def param1 = getYourParam1();
def param2 = getYourParam2();
def param3 = getYourParam3();
def query = jqlQueryParser.parseQuery("description ~ " + param1 + "AND description ~ " + param2 + "AND description ~ param3")
Then you would need to decide where you would store your parameters.
And you have many choices:
You could:
store it in the file system near your script
store in a custom field for each issue
store as an issue property
store as a project property
store it in SAL
store it in a database
and so on
Like SRE_Chaos likes this
Hi Alexey...thank you for your assistance...I finally had the time to test this out but it is still not working...the issue is with the line with the JQL...I am parsing the summary of the issue being created and I am properly getting param1, param2, and param3 but building the JQL is not working...it gives a syntax error...and also param1, param2, param3 may be JIRA reserved words as well. So for instance, if param1 = account-authn, param2 = access, and param3 = 1.5.0, the following line works fine:
def query = jqlQueryParser.parseQuery("description ~ 'account-authn' and description ~ 'access' and description ~ '1.5.0'")
but of course I need this to be with the values in param1, param2, param3
Here is the error I got:
com.atlassian.jira.jql.parser.JqlParseException: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException
 at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseClause(DefaultJqlQueryParser.java:96)
 at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseQuery(DefaultJqlQueryParser.java:32)
 at com.atlassian.jira.jql.parser.JqlQueryParser$parseQuery.call(Unknown Source)
 at Script7.run(Script7.groovy:36)
Caused by: com.atlassian.jira.jql.parser.antlr.RuntimeRecognitionException
 at com.atlassian.jira.jql.parser.antlr.JqlLexer.checkAndSet(JqlLexer.java:100)
 at com.atlassian.jira.jql.parser.antlr.JqlLexer.mSTRING(JqlLexer.java:1676)
 at com.atlassian.jira.jql.parser.antlr.JqlLexer.mTokens(JqlLexer.java:2656)
 at org.antlr.runtime.Lexer.nextToken(Lexer.java:85)
 at org.antlr.runtime.BufferedTokenStream.fetch(BufferedTokenStream.java:143)
 at org.antlr.runtime.BufferedTokenStream.sync(BufferedTokenStream.java:137)
 at org.antlr.runtime.CommonTokenStream.consume(CommonTokenStream.java:71)
 at org.antlr.runtime.BaseRecognizer.match(BaseRecognizer.java:106)
 at com.atlassian.jira.jql.parser.antlr.JqlParser.operator(JqlParser.java:1214)
 at com.atlassian.jira.jql.parser.antlr.JqlParser.terminalClause(JqlParser.java:645)
 at com.atlassian.jira.jql.parser.antlr.JqlParser.notClause(JqlParser.java:555)
 at com.atlassian.jira.jql.parser.antlr.JqlParser.andClause(JqlParser.java:432)
 at com.atlassian.jira.jql.parser.antlr.JqlParser.orClause(JqlParser.java:366)
 at com.atlassian.jira.jql.parser.antlr.JqlParser.clause(JqlParser.java:328)
 at com.atlassian.jira.jql.parser.antlr.JqlParser.query(JqlParser.java:237)
 at com.atlassian.jira.jql.parser.DefaultJqlQueryParser.parseClause(DefaultJqlQueryParser.java:89)
 ... 3 more
Alexey Matveev
January 18, 2018
It must be
def param1 = "account-authn"
def param2 = "access"
def param3 = "1.5.0"
def myQuery =  "description ~ \"" + param1 + "\" AND description ~ \"" + param2 + "\" AND description ~ \"" + param3 + "\""
log.error(myQuery)
def query = jqlQueryParser.parseQuery(myQuery)
Kindly check in the logs that myQuery is correct
You are the man!
Thank you so much for your help Alexey!
Like Lilian Tong likes this
Lilian Tong December 22, 2020
I agree, thank you Alexey. This helped big time!
abdul shaik
March 29, 2023 edited
Hi @Alexey Matveev  need your help i need to pass parameters in cmd line for jql query
HOW TO ACHEIVE THAT
# set up the JQL query to search for issues
jql = 'project = XXXXXINT AND status = "To Do"'
# set up the parameters for the search request
params = {
'jql': jql,
'maxResults': 50,
'fields': 'summary,issuetype,assignee,status,reporter,description,created'
abdul shaik
March 29, 2023
@alexey  the out put execution in cmd should be like        jiraQuery.py XXXXXINT To Do
to pass parameters like above in cmd line what needs to be done in my python script
Register here ⬇️
