How to bulk add options to a custom field via CLI
Julio Valdez
I have a custom filed with drop down options (over 100) and would like to do this via CLI.
Any idea?
Thanks in advance.
Bob Swift
June 9, 2015
Sorry, there currently isn't any remote API support for doing this type of configuration.
Tyler Anderson March 16, 2018
Hello @Bob Swift, has this option been created yet?
Bob Swift {Appfire}
No. As far as I am aware, there is still no REST API support available from Jira.
I searched this and I believe you are correct. Although, I found a way to accomplish this. If you have the script runner add-on and use the "built-in scripts" then you can bulk import custom field values.
