How to bulk delete Inactive/Draft workflows
Lokesh D
Need to delete more than 100 Inactive/Draft workflows.
Wondering if there is there a automated way to achieve this, via any scripting methods ?
17 votes
Jeff Ward
February 23, 2016 edited
If you have the ScriptRunner plugin, the following script will delete all inactive workflows for you, ignoring the "classic' workflow.
def workflowManager = ComponentAccessor.workflowManager
def schemeManager = ComponentAccessor.workflowSchemeManager
def sb = new StringBuffer()
workflowManager.workflows.each {
if(!it.systemWorkflow) {
def schemes = schemeManager.getSchemesForWorkflow(it)
if (schemes.size() == 0) {
sb.append("Deleting workflow: ${it.name}\n")
workflowManager.deleteWorkflow(it)
return sb.toString()
Note this will not delete inactive schemes, only inactive workflows.  Modifying this to find inactive schemes should be possible.
Yevhen L March 5, 2016
A quick note: system default workflow should be assigned to some scheme, otherwise script won't work.
Like • 2 people like this
Ansar Rezaei
August 20, 2016
Thank you so much.
It work for me using Yevgen suggestion.
David Skreiner
October 4, 2016
Unfortunately ScriptRunner is no longer free, but has gone commercial / expensive, so many people can't follow the suggestion.
 It's frustrating to Admins and harmful to Atlassian's reputation that so many problems (including some horrible spots in the UI, such as this Delete Workflow UI or the user picker) can only be solved by spending a lot of money on plugins.
Like • 6 people like this
Thomas Bores March 9, 2017
I definitively agree with you!
Like • Ian T Price likes this
Deepa Tantry June 27, 2017
Hi Jeff,
This is of really good help! Thank you!
Can you please let me know if using the below line instead of delete phrase in the script would help me just list the inactive workflows?
workflowManager.findWorkflow(it)
Like • Sundareswaran K likes this
Bill Neff
September 29, 2017 edited
The following snippet should work to delete all inactive workflow schemes.  Coupled with the script above, it should clean things up:
schemeManager.schemeObjects.each {
try{
if(schemeManager.getProjectsUsing(schemeManager.getWorkflowSchemeObj(it.id)).size() == 0) {
sb.append("Deleting workflow scheme: ${it.name}\n")
schemeManager.deleteScheme(it.id)
catch(Exception e) {
//noop
sb.append("Error: " + e + "\n");
Like • 10 people like this
Nabil Assi October 19, 2017
Both scripts work like a charm, cleaning up the workflows and the Worflow Schemes.
For some reason one of my workflows cannot be deleted. The logs shows that is it assigned to a scheme eventhough it`s not anymore. So i had to add the "catch exception" to the script to bypass it.
Tej
Hey Bill,
I'm trying to edit these excellent scripts to bulk delete other schemes like issue type, issue type screen scheme, got stuck, can you plz help with other bulk delete scripts too
https://community.atlassian.com/t5/Adaptavist-questions/How-to-bulk-delete-screen-schemes-or-issue-type-schemes/qaq-p/712428
Thank you
Bill Neff
Scripts for deleting unused Issue Type Screen Schemes and Screen Schemes are here: https://community.atlassian.com/t5/Adaptavist-questions/How-to-bulk-delete-screen-schemes-or-issue-type-schemes/qaq-p/712428
Like • Ahsan likes this
Tej
Hey Jeff Ward
When I tested bulk delete inactive workflows, got this error
Associated default workflow to other workflow schemes too
Jeff Ward
I just got this as well. I've modified the answer to avoid looking at schemes for the system workflow.
Raju Adluru August 1, 2018
Hi Jeff
Can this script prompt for me to delete or not to delete?
or can i put a criteria to delete only old inactive workflows which are modified in 2016, 17, not in 2018?
Thanks for your help.
Corentin Bresson July 18, 2019
Hi Jeff,
Thanks for your script.
To be be precise, it will delete workflows that are not associated with any Workflow Scheme.
A workflow that is associated with a Workflow Scheme will not be deleted, even though the Workflow can be inactive, and appear as such on http://<jira>/secure/admin/workflows/ListWorkflows.jspa .
This is because the Workflow Scheme(s) that a Workflow is associated with can be itself active (ie associated with a project) or inactive (not associated with any project.
Like • Masco likes this
Ahsan September 1, 2019
Is there any script to delete unused Field Configuration Schemes, Field Configurations and Fields?
Also, Unused Issue Types Schemes and Issue Types.
Thanks in advance.
12 votes
Kyle
May 8, 2019 edited
For those of you who would like to avoid buying ScriptRunner just for this clean up task, have a try with this awesome solution: https://gist.github.com/zionyx/378ba519239bf040b2a6310b68d2740d
You are most welcome. :)
Ahmad July 3, 2019
you're awesome!!
Vitali Ermakov
July 15, 2019
Works fine with Safari.
Mason Crouse
June 9, 2020 edited
Worked for me in Chrome
Kirk Garcia
January 26, 2021
perfectly works - thanks for the suggestion.
Alex
May 28, 2021
Thanks a lot. Works in Opera.
Maksim Beliaev
brilliant!
jv_sogorb December 10, 2019
I have created a simple script that you can execute it in chrome. No need to install or pay anything.
Execute it until you get rid of all deleteable workflows.
function
 deleteNext(){    waitAndClick('#inactive-workflows-module-heading h3', () => {        waitAndClick('[data-operation="delete"]', () => {            waitAndClick('[name="Delete"]')        })    })    document.querySelector('[data-operation="delete"]').click()    document.querySelector('[name="Delete"]').click()}
function waitAndClick(selectorcallback) {    const el = document.querySelector(selector);    if (el) {        el.click();        return (callback? callback() : null;    }    return setTimeout( () => {        waitAndClick(selectorcallback);    }, 100);}
deleteNext()
Nika
Got Syntax error
Joe Doperalski
August 6, 2020
nice.  I needed to add some semi colons...
function deleteNext(){
waitAndClick('[name="Delete"]');
document.querySelector('[data-operation="delete"]').click();
document.querySelector('[name="Delete"]').click();
function waitAndClick(selector, callback) {
if (el) {
el.click();
return (callback) ? callback() : null;
waitAndClick(selector, callback);
}, 100);
deleteNext();
cj little July 24, 2021
If you're running Jira Cloud and you'd like to delete all the workflows that Jira is willing to allow you to delete, then consider running the following script in ScriptRunner:
// Get a list of the first N Workflows (appears that N is max of 50)
Map<String, Object> searchResult = get('/rest/api/3/workflow/search')
.queryString("maxResults", "200")
.asObject(Map)
.body
def w = (List<Map<String, Object>>) searchResult.values
// Iterate over all the Workflows; Attempt to delete everyone :eek:
w.each {
if (it.id.entityId != null) {
println "Attempting to delete: ${it.id.entityId} - ${it.id.name}"
def hr = delete('/rest/api/3/workflow/'+ it.id.entityId).asString()
println hr
If you'd like to delete all the unreferenced Workflow Schemes, try this snippet:
// Get a list of the first 200 Workflow Schemes
Map<String, Object> searchResult = get('/rest/api/3/workflowscheme')
.asObject(Map)
.body
def ws = (List<Map<String, Object>>) searchResult.values
// Iterate over all the Workflow Schemes
ws.each {
// Only want the Workflow Schemes without any mappings
if (it.issueTypeMappings.size() == 0) {
println "Deleting: ${it.id} - ${it.name}"
def hr = delete('/rest/api/3/workflowscheme/'+ it.id).asString()
println hr
I've posted these in my GitHub Repo for forking and updating goodness.
I hope this saves you a couple hundred clicks, hours of your life, and puts a little smile on your face when you are making thankless changes cold and alone in the depths of Jira.  Please enjoy the hours this puts back in your life doing anything other than Jira Administration.  You've earned it.
Eva
February 8, 2012
Well I do it the way that Atlassian might not suggest: directly on the database itself. There is a table call Workflow_Draft (or something like that ) that I can just run a delete statement and then I just reindex the whole JIRA and restart the program. It works for me (in 4.4.1). But again, anything directly to database is not recommended, I guess I have just been lucky.
