×Use JIRA Command Line Interface (CLI) and get a CSV file with them all listed:
--action runFromProjectList --common "--action getVersionList --project @project@ --file versionList.csv --append --outputFormat 999"
Using the rest API this is your best bet:
Use /rest/api/2/project
to get all accessible projects.
Extract the project keys, and loop over every project key.
Use /rest/api/
2
/project/{projectIdOrKey}/versions
to get all versions for a specific project.
Accumulate all of the results.
This is another thing that is a lot easier to do via mysql (if you have access to the database):
mysql> select DISTINCT vname from projectversion;
| vname |
| Release 1.0.2 |
| Release 1.0.3 |
(JIRA 6.2.1)
Hi Xinan,
You can use REST API to get list of all versions in the projects
/rest/api/2/project/{projectIdOrKey}/versions
For more info you can refer - https://docs.atlassian.com/jira/REST/latest/#d2e2079
Taha
Register Now
