How to bulk upload different values
Ramu
November 6, 2024 edited
Hi All ..
I'm aware of how to update one value(one Label) in multiple EPICs in bulk upload ..
I have a scenario like :
I have 50 Unique Labels(Label 1, Label 2 .. Label 50)
All these have to updated in 50 different EPICS (Existing EPICS)
like
Label 1 in existing Epic 1
Label 2 in existing Epic 2
Label 50 in existing Epic 50
Is there a way to do it in bulk !!??
OR
is there a way to do it through JQL ??!!
Marc - Devoteam
November 6, 2024
Hi @Ramu
This can't be done in Bulk.
As bilk edit acts on alls the issues chosen.
You want to update a specific field for each issue, you can to this via CSV import, make sure to list the existing keys in the CSV.
This will ensure the existing issue will be updated
Ramu
Hi Marc ..
Well said .. exactly i tried  but met with an obstacle in the Bulk update process where i couldnt map the 'Issue Key' field ..
i mean for other fields like Summary, Description, Issue Type etc .. i was able find the exact match in the corresponding drop down and so i was able to select it and mapped those.
however, for the 'Issue Key' field, in the drop down there was no exact match like Issue Key available and i couldn't map it .. this resulted in i end up creating new Tickets instead of updating the existing ones !!
 anything in JQL like 'Change Label or append label etc ..' (not there at present i believe) ..
any other workaround ?!
Marc - Devoteam
November 7, 2024
Hi @Ramu
There is no JQL for this.
The only option is CSV import, to update your issues.
In you CSV specify the issue keys also in a column, so the exiting issues will be updated.
Hannes Obweger - JXL for Jira
Hi @Ramu
if you're open to solutions from the Atlassian Marketplace, you may want to have a look at the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a long list of advanced features, including the ability to bulk edit your fields using copy/paste. This works within JXL, but also between JXL and pretty much any other tool, including e.g. Excel or Google Sheets.
So what you could do is to open your data in e.g. Excel, and simply copy/paste the values over, like so:
I'm using story points here, but it would work the same way for any other issue field(s). You don't actually need the issue key; you just want to make sure that you paste into the correct set of issues.
Just be aware that JXL's copy/paste logic currently replaces the existing labels, rather than adding to them. If it's the latter that you're looking for, I can advice on this, too.
I should also add that JXL can do much more than the above: From support for configurable issue hierarchies, to issue grouping by any issue field(s), sum-ups, or conditional formatting.
Best,
Hannes
Aaron Pavez _ServiceRocket_
Hi @Ramu
Maybe the CSV isn't set correctly?
https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
Go to Updating existing issues, copy the example and use that.
Regards
Ramu
Hi Aaron,
To avoid any such incorrect csv scenarios .. what i did was .. first i extracted few of the existing EPICs as a csv file ... Then tried importing the same csv with the new labels (Label 1 .. Label50) in the csv updated.
and the validation (Validate ..before 'Begin Import') was perfectly fine .. so it is all fine with csv template and fields ..
i have standard level of Admin access otherwise, i couldve done this via JIRA administration/system settings/external import ...
(but getting that level Admin access is not possible in the org where i work)
Even ..tried from JQL perspective of trying to update the existing Label like change/update/amend/append Label but as you are aware , none of these are available/possible in JQL .. ()
so, concluding all these tried my luck of checking here to see any workaround or alternate option/thoughts ..
