×Hi,
Is there a way to calculate the square root of a field (I have a select list with different numeric values) and display the result in another field?
thanks!
Actually I found a way (Calculated Number Field):
<!-- @@Formula:
if (issue.get("customfield_11733")==null) return null;
return Math.sqrt(issue.get("customfield_11733"));
You'll find that you have most basic Java math functions. Misc Custom Fields uses Beanshell scripting language itself.
Please share the formula you have used.
This is not avaliable out of the box.
A plugin like Misc Calculated Fields or Scriptrunner can accomplish this, otherwise it is usually accomplished by writing a Custom Field add-on (for Server) or Issue Field integration (for Cloud).
hmmm yeah i already have Misc Calculated Fields, i tried with a calculated field, but i can't figure out which formula is needed.
