Hi Team,
Trying to calculate the balance ticket of each month, the value should be accumulate, but seems the query ( in bold ) not works, can someone please help to check? Thank you.
An example with screenshot attached:
in Oct 2024, New ticket is 24, resolve 0, Balance is 24
in Nov 2024, New ticket is 13, resolve 8, Balance is 5, but the exactly balance value i want should be balance of Oct 2024 + balance of Nov 2024 : 24+5=29
in Dec 2024, New ticket is 9, resolve 3, Balance is 6, the balance value i want is :
balance of Oct 2024 + balance of Nov 2024+ balance of Dec2024 = 24+5+6=35
and so forth.
I had use : sum(COALESCE(T1.'Count',0)) over(order by T1.'Created')
-sum(COALESCE(T2.'Count',0)) over(ORDER BY T1.'Created') AS 'Balance'
but seems not work.
-------------Here goes the SQL i had used ----------------------------------
SELECT
T1.'Created' AS 'Date',
COALESCE(sum(T1.'Count'),0) AS 'NEW Ticket',
COALESCE(sum(T2.'Count'),0) AS 'Resolved',
/*sum(T1.'Count') OVER(order by T1.'Created') AS 'Balance'*/
from T1 left OUTER JOIN T2 ON T1.'Created'=T2.'Resolved'
group by T1.'Created'
Concerning our Table Filter, Charts & Spreadsheets for Confluence app, please, try the following SQL as an alternative:
CREATE TABLE TT1;
INSERT INTO TT1
SELECT
COALESCE(sum(T2.'Count'),0) AS 'Resolved ',
group by T1.'Created';
SELECT TT1.'Date',TT1.'NEW Ticket', TT1.'Resolved ', TT1.'Balance' + (SELECT COALESCE(SUM(TT2.'Balance'), 0)
FROM TT1 AS TT2 WHERE TT2.'Date' < TT1.'Date') AS 'Balance' FROM TT1
NB. Also, please, make sure the date format in the macro settings is set to M yy, as your source output suggests to make the transformation work properly.
Best wishes,
Nikita
Hi Nikita,
Thank you so much, it worked! Now the result is ok.
One more question, for the SQL it still have a warning messages , do you have any idea about it?
Hi @Nikita Kamai ,
After update the date format in the macro settings is set to M yy, the warning message got removed. Thank you so much! Really appreciate your help.
Help us plant more trees
