Hi All, How can i calculate the total time spent while closing(from open) an issue in JIRA. Please advise.
Here is a version for culculated field provided by ScriptRunner.
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.changehistory.ChangeHistory import com.atlassian.jira.issue.changehistory.ChangeHistoryManager import com.atlassian.jira.issue.history.ChangeItemBean /** * Return time between two statuses */ //Issue issue = null; long endStatusTime = 0; String endStatusName = "Закрыт" ChangeHistoryManager changeHistoryManager = ComponentAccessor.getChangeHistoryManager(); for(ChangeHistory changeHistory: changeHistoryManager.getChangeHistories(issue)) for(ChangeItemBean changeItemBean: changeHistory.getChangeItemBeans()) { if (changeItemBean.getField().equals("status")){ if( changeItemBean.getToString().equals(endStatusName) ){ endStatusTime = changeItemBean.getCreated().getTime() } } } return String.format("%.2f", (endStatusTime - issue.getCreated().getTime())/(1000*60*60*24))
If you do not want to use this plugin you could get this data via SQL.
