Some of our team members have looked at copying and pasting JIRA screens into powerpoint and using for presentations, reporting, etc, and obviously find it cumbersome. What they would love to do is go to a JIRA dashbaord and capture a set of gadgets on screen at that instant in time, and publish to Confluence via AppLinks. Data to remain static so it can be referenced by teams in the future. Anyone seen a plugin like this or know an alternate way to rapidly publish gadgets and dashboards on the fly from JIRA to Confluence?
I would like that feature for reporting
@Mick Flanigan- I'm also looking for the same feature, were you able to get what you wanted?
No answer yet that will work for what we are trying to do. Thanks to those that gave feedback though!
You could use http://getgreenshot.org/ to create a screenshot. The tool provides JIRA and Confluence plugins to upload the screenshot instantly to a JIRA issue or Confluence page. Maybe this make the process a little bit easier.
Henning
Will have to check into this and see if it meets the requestors needs.
You could insert JIRA gadgets to Confluence page, however in incorporating thw whole dashboard, I don't think we could do that apart from including through HTML macro.
Hope it helps.
Thanks Rian, I am not sure if this is quite what I am looking for here. We want to take snapshots of gadgets that remain static on Confluence. For repoting and historical review. Right now I believe aside from a screenshot, the gadgets that are rendered in Confluence are all dynamic. tehy will show the latest data to pass the filters applied. Simply looking for a quick way (1-2 clicks) to publish the contents of a dashboard to a confluence page in a static view.
Learn more
