How to catch exceptions in JIRA REST API - Python SOLVED
draganvucanovic April 9, 2019 edited
I want part in except block to be executed if error faced in try block, error is raised if customfield_10005 has incorrect value, so i purposely set wrong value for customfile_10005 but again except block is not executed, what's wrong with this code ?
customfile_10005 is JIRA Epic ID and i want not to raise errors if that ID is wrong:
from jira import JIRA
from jira.exceptions import JIRAError
try: headers = {"Content-Type": "application/json"} data = {"fields":{"project":{"key":"CP"},"issuetype":{"name":"Task"},"reporter":{"name":reporter},"assignee":{"name":reporter}, "summary":"Pre-Sales - Placeholder - 1/5 {this_month} - {reporter}".format(**locals()), "description":"descriptions", "customfield_10107":{"id":"10400"}, "customfield_11300":{"value":"Engineering"}, "customfield_11301":{"value":"York"}, "customfield_10005":200 }} response = requests.post('https://jira.company.com/rest/api/latest/issue/', data = json.dumps(data),auth=('user', password), headers= headers) print (response.content) except JIRAError as e:
print ("some errors")
Instead of  "some errors" i specified, i'm getting default error message
b'{"errorMessages":["Issue can be assigned only active or future sprints."],"errors":{}}''
draganvucanovic April 10, 2019
I used response output to create "error handler" (because exception block doesn't work), if in response output there is string errorMessages, run "exception block"
"customfield_10005":200}}
print(response.content)
out = response.content
if b'errorMessages' in out:
   data = {"fields":{"project":{"key":"CP"},"issuetype":   {"name":"Task"},"reporter":{"name":reporter},"assignee":{"name":reporter},
   "description":description",
