How to change color of custom field
Cedric_DEVAUX
I create a customfield "VIP User" and I want to change the color of this customfield.
I tried to define back ground color in Edit Custom Field
I tried this but it doesn't work
<html>
<body bgcolor="#FF0000">
</body>
</html>
I'm not sure it's the right method to change the bgcolor of this customfield
How can I do?
Thank you!
Cedric
Deepali Abhyankar
June 28, 2018
I have a similar requirement. @Cedric_DEVAUX , did you find a solution?
Charles Huggins August 16, 2018
Hi There! You can try this plugin: https://marketplace.atlassian.com/apps/1219385/rainbow-field?hosting=server&tab=overview
We also much apprecated any feature requests!
Cedric_DEVAUX
Hi Ollie,
Thank you for your answer smile
I tried these plugins but it doesn't correspond of my need because it create a new customfield with a color box.
I need to define a script or something else to detect when the value of customfield VIP User is "VIP" to change the background color or the font color of this customfiel.
Cedric
Arianna Fabbri
Hi @Cedric DEVAUX , did you find a solution? Thank you Regards Arianna
Register now
