When I create a issue,there should be write describe in blank .
Now I want to change the form of the describe.
The form of the describe is
when :
what :
where :
why :
who :
I want to fasten the "5W" in the describe , then users only write comment after "5w", it just look like this(users only write the bold character)
when: 2012/10/20
what : the jira issue
where: China
why: Jira can't use
who: wangyu
Is there any plugin can solve this problem?
Or Could I make the "5W" to a item ?
You can create a "Unlimited Text Field" custom field and set the default value to your 5 W's.
Then in your field configuration, you the custom field and hide the description field
Now I find "Unlimited Text Field" custom filed when I create a field ,But how could I set the default value to 5W . When I select Unlimited Text Field, there only write describe with this field ,could not set the default value to 5W. How could I solve this problem?
