How to change project category through script console?
Marat August 21, 2019
I am trying to mass transfer projects from one category to another.
import com.atlassian.jira.project.ProjectCategory
import com.atlassian.jira.project.ProjectManager
def projectManager = ComponentAccessor.getProjectManager()
String[] projectList = projectManager.getProjectObjectsFromProjectCategory(10300)
def i
for (i = 0; i <= projectList.length; i++){
 projectManager.setProjectCategory(projectList[i].minus('Project: '), 'Close')
No signature of method: com.atlassian.jira.project.CachingProjectManager.setProjectCategory() is applicable for argument types: (java.lang.String, java.lang.String) values: [PFO, Close] Possible solutions: setProjectCategory(com.atlassian.jira.project.Project, com.atlassian.jira.project.ProjectCategory), getProjectCategory(java.lang.Long), createProjectCategory(java.lang.String, java.lang.String)
4 votes
PD Sheehan
August 21, 2019
By defining your projectList as String[] ... you are hamstringing yourself. Just get them as objects.
Then you also need to get the object for the target new category.
And finally ... this is groovy ... leverage it for simplicity
Try this
def projectManager = ComponentAccessor.projectManager
def projectList = projectManager.getProjectObjectsFromProjectCategory(10300)
def newCat = projectManager.getProjectCategoryObjectByName('Close')
projectList.each{
projectManager.setProjectCategory(it,newCat )
Likhitha Kosanam June 15, 2023
Hi ,
Where to pass the projects? I need to set Project category for few projects .
Please suggest.
Regards
Likhitha
PD Sheehan
June 15, 2023
Try this in the console:
import com.onresolve.scriptrunner.parameters.annotation.ShortTextInput
@ShortTextInput(description = "List of project Keys separated by commas", label = "Project Key List")
String projectListString
@ShortTextInput(description = '', label = "New Category")
String categoryName
def projectList = projectListString.tokenize(' ,').findResults { pkey ->
projectManager.getProjectByCurrentKey(pkey)
def newCat = projectManager.getProjectCategoryObjectByName(categoryName)
if (!newCat) {
return "There is no category by the name $categoryName. Manually assign that category to one project from the project settings first, then come back here to bulk-update more projects."
projectList.each {
projectManager.setProjectCategory(it, newCat)
Like Luca Andreatta likes this
Likhitha Kosanam June 20, 2023
please check this
PD Sheehan
June 20, 2023
The point of the script I wrote was to give you a simple tool to use in the console.
This is what it is supposed to look like:
Like Deepali Kohli likes this
Likhitha Kosanam June 21, 2023
Hi @PD Sheehan ,
Thank you so much. :-)
Regards
Likhitha
