Hello everyone,
i'm trying to change a project lead to unassigned, but there is no option to do this. I click on "edit defaults" and can change the project lead to anyone else but not to none or unassigned.
Hello everyone, i'm trying to change a project lead role to unassigned, but there is no option to do this.
When I click on "edit defaults" i can change the project lead to anyone else but not to "none" or "unassigned".
Does anyone know how to do this? I'm working with Jira v9.4.21 Datacenter Version
Best regards
Rainer
Hi @Rainer Israel , Welcome to the community!
Project lead is a unique role in project and cannot be empty, by default it is the person creating the project.
https://confluence.atlassian.com/adminjiraserver0904/defining-a-project-1188767910.html
However, if you are facing the issue that all created issues are assigned to project lead, then you need to change the configuration of default assignee in components section, here you can read more about it: https://confluence.atlassian.com/adminjiraserver0904/managing-components-1188768051.html
Hello Lukasz,
that was a really quick answer. I didn't know that there has to be a project leader.
Rainer
