How to change the assignee when issue moves to another project?
lena_vasich July 25, 2024
What I need:
If the issue is moved to another project
and
current assignee is not in one of roles of a new project (= has no permission to be assigned)
then
change assignee to project lead.
What I made:
What error do I have sometimes:
Action details:
User condition
Unexpected error executing rule:
java.lang.NullPointerException
What should I change?
Anandhi Arumugam [Cprime]
Hi @lena_vasich You can try something like this. Hope this works for you.
Thank you for your answer. You mean add logging action? I'll try, ok
Hi @lena_vasich Can you try adding a condition to check if the issue has an assignee? Also try to log the smart value's result and the assignee to see why it failed for specific issues. Also check rule actor to see if it is Automation for Jira.
Like Gaurav Arora likes this
Genius! There can be no assignee =) that's why nullPointer
Thank you!
Glad that helped!
Gaurav Arora
I would suggest you to double check if the target project have a Project Lead or if the current Lead is an active user. Also, try this rule with another target project.
Apart from this, I don't see any error with your approach. I replicated it and it worked for me.
Thank you for your answer. Project lead is active, everything is fine with it...
Sometimes this rule works, sometimes not, I can't understand why can I have the nullPointer..
