How to change the colors of flags ?
Ashkan Malekly
March 26, 2019
i want to change the colors of flags could u help me
Best regards
Mehmet Şirin Usanmaz
March 26, 2019
Hi Ashkan,
Unfortunately this is not possible.
Mehmet Sirin
Ashkan Malekly
March 27, 2019
Thanks Mehmet Sirin.
Baris Guner
Hi @Ashkan Malekly  & @Mehmet Şirin Usanmaz
This is possible via the free Color Cards version 1.0.1 from :
https://marketplace.atlassian.com/apps/1219454/color-cards-for-jira/version-history
If you get the later versions though they removed the color overriding unfortunately.
Once you get it set the colors based on Queries and as "Flagged is not EMPTY" and choose your favorite color.
In fact you can color other cards with this plug-in according to many other status fields etc.
Baris
Baris Guner
Baris
