How to change the rest script?
Dmitrii Strukov
I'm not sure if this is the standard api, but there is an endpoint like this:
/rest/keplerrominfo/databasecf/latest/autocompletedbcf/children?decorator=none&seldbparentvalue=STRING&dbcf=customfield_11711&_=1607344621465
it used to return this response:
[{"id": "customfield_11712", "value": "63F1162A-1C89-96C1-44AB-5EAA73B19547"}]
after someone changed the settings, he began to return a different answer
[{"id":"customfield_10107","value":"63F1162A-1C89-96C1-44AB-5EAA73B19547"}]
customfield is different now.
I have a test jira on another server, and it has almost the same data, but its settings have not been changed and it works fine.
I do not understand what needs to be changed to change the answer of endpoint?
Sam Hall
December 7, 2020
Hi Dmitrii,
I think this endpoint might be provided by 'Power Custom Fields'
https://marketplace.atlassian.com/apps/1210749/power-custom-fields-for-jira?hosting=server&tab=overview
Do you have that add-on installed?
Sam
