How to change the sprint of closed issues?
Vineet Kumar
Hi All, There are some issues which are mistakenly moved from a different sprint (not sure how), but i am not able to change the sprint, i have tried adding sprint field in edit issue screen and add a workflow transition from closed to open with the screen field added on the transition screen, the screen is correctly assigned to the project, Sprint field is in the edit screen, properties are fine too, other field are editable, i am not sure if i am missing something the sprint field is non editable every where and in every status.
James Strangeway
December 14, 2015
Do you have the Manage Sprints permission?
Vineet Kumar
Yes i do have
