How to check if Security Level field is hidden on screen using Behaviour Script Runner ?
Paridhi Agarwal March 8, 2018
Using Behaviour, how can we check if Security Level field (which is a JIRA System field) is hidden on screen ?
Kyle Moseley
March 11, 2018
This is rough so you would want to flesh out the logic, but in general this should work.
def issue = getUnderlyingIssue()
def sec = getFieldById("security")
log.debug issue?.getSecurityLevelId().toString()
log.debug sec?.getValue().toString()
if (issue?.getSecurityLevelId().toString() == sec?.getValue().toString()) {
log.debug "Security Level not hidden"
} else {
log.debug "Security Level hidden"
There are other approaches (like using the Field Config API) but I think this one is very simple.
Kyle Moseley
March 20, 2018
Hi. If this answer helped, please use the check mark to accept the answer. Thanks!
