How to check values of field in workflow?
Josef Sigl May 16, 2024
  • I've a field (typ: Chekbox) and we use it currently only with 1 selection.
  • Now I'd like to give it more selectios, but it shall be select only one of them.
  • Ich want to make it in workflow with an check and if the user select more than one, he should get an error Message!
  • How can i do this? We use JMWE app
regards
Josef
David Fischer
Hi @Josef Sigl
using JMWE, you can create a Scripted (Groovy) Validator with a script like:
issue.get("my checkbox custom field name or ID")?.size() == 1
hi david, i'll try it and giv you feedbck - thx
Josef Sigl May 17, 2024
Hello David, i've done as you told, but it does'nt work. I get an error message - please look at the screenshots
David Fischer
Hi @Josef Sigl
please replace the script with:
issue.get("customfield_10375")?.size() == 1
Hi David, it works !
thanks a lot
David Fischer
Hi @Josef Sigl
I'm glad it worked.
Can you please "Accept" the answer so that others can benefit from it?
Josef Sigl May 21, 2024 edited
Hello David, unfortunately it doesn't work perfectly ;-/
This error message should only appear, if someone enters 2 values. If someone enters only 1 value or no value, there should be no error message.
Do you have an idea how I can solve this?
regards
Josef
Hello David, I've already found the solution.
issue.get("customfield_10375")?.size() <= 1
It works ;-)
regards
Josef
Jeroen Poismans
Hi!
If you only want 1 selection to be possible, why not use Radio button type control?
Jeroen
Hello Jeroen,
the field exists for a long time and I don't want to create a new one, because all queries inklude this field would no longer work.
So I'd like to regulate this with an Validator-check
Regards
Josef
SERVER
Register here ⬇️
