I am planning on migrating a 6.7 bamboo server to a host which already has other Atlassian applications like JIRA and CONFLUENCE and BITBUCKET.
It looks like I may want to modify my BAMBOO instance to use at URL which includes the /bamboo context for access differentiation.
I tried to modify the 6.7 instance by use of the ADMIN GUI interface using
SYSTEM -> GENERAL CONFIGURATION
changing Base URL
TO: http://10.xxx.xxx.40:8085/bamboo
But on restart the path http://10.xxx.xxx.xx:8085/bamboo URL would not resolve
Is there something else that needs to be changed?
Also .... I noticed that the remote agent wrapper.conf still utilized the non "/bamboo"
value for:
wrapper.app.parameter.2=http://10.xxx.xxx.40:8085/agentServer
Is there way to properly change the URL and push all required changes?
If not, what manual changes must also be made?
T.S.
Hi @timothy schmidt,
Steps are outlined for how to change the context path.
I was actually looking at this one before I left last night .... :-)
But I'm curious then whether or not the documentation referencing the GUI action
https://confluence.atlassian.com/bamboo/specifying-bamboo-s-url-289277242.html
is not accurate, or perhaps the solution to a different problem set?
Tim
Same problem set, this comes after you've changed the context path on the server.
Ah! .... I thought this actually would drive the change(s) - with a service restart of course ... my bad.
Thanks for clarifying this.
Tim
Register today
