I need to create an automation where the fields 'description', 'assignee', and 'summary' should be cloned from the parent task to the sub-task. However, I couldn't make it work.
Welcome to the community. When do you want to cloned parent issue's field values into your subtasks? I am assuming that the subtasks were already created, but you want them to have parent issue's summary, description, and assignee to be carry over into the subtasks?
Please provide more information, so we can better assist you.
Best, Joseph Chung Yin
Thanks Joseph!
I want to clone the information at the time of subtask creation.
Hi @Marilia Ximenes de Araujo ,
You can create an automation rule to copy field values from the Parent issue to Sub-task issues.
Add Trigger- When Issue Created
Add Condition- If Issue type = Sub-task Issue type
Add New Action- Edit Issue
Select the field names and change it to copy from Parent.
Save the automation.
I did it this way (sorry for being in Portuguese. I'm from Brazil).
But it would be:
Add trigger - when the issue is created
Add condition - if issue type = subtask issue type
Add new action - clone item to
(choose the field where I want to clone to the parent item)
That's because I want to clone it at the moment I create a new subtask.
Hi @Marilia Ximenes de Araujo and welcome to the Community!
Can you specify whether it's Server/DC or Cloud?
These Screenshots are for Cloud:
You need the Edit issue Action.
1. Under "Choose fields to set" pick whatever fields you want to copy
2. (...) change to "COPY"
3. Click on the "Copy xxx from xxx" and change to Parent issue
