×Hi All
I have the clone plus plugin and i have disabled the native clone operation.
I observe that the clone ++ operation does not allow me to clone sub-task issue types.
Can anyone suggest how i can clone sub-tasks using clone ++
Rahul
Subtasks can only be cloned to subtasks of the same parent. The clone+ action or a custom action based on that will be able to clone the subtask.
Thanks that helps
Unfortunately, it doesn't help us in our use case..
We are evaluating the plugins Clone Plus and Exocet.. In our opinion Clone Plus does a better job but because of the missing clone feature (clone subtask to <issuetype> in another project), we are not sure that this is the right one for us
With Ecocet, we can use this feature in subtsaks.
I really hope that you can implemate this feature in a near future.
Thank you.
