Help me on this problem
Thanks in advance
And what is the problem that you are facing?
Hi there,
There some documentation over at the developer sire which shoes you. You need to use the Issue Service object to transition your issue through the workflow, assuming your issue has a valid route to the close status, then it's quite simple.
IssueInputParameters issueInputParameters = new IssueInputParametersImpl(); issueInputParameters.setAssigneeId("newdude"); IssueService issueService = ComponentManager.getInstance().getIssueService(); TransitionValidationResult transitionValidationResult = issueService.validateTransition(user, 12345L, 10000L, issueInputParameters); if (transitionValidationResult.isValid()) { IssueResult transitionResult = issueService.transition(user, transitionValidationResult); if (!transitionResult.isValid()) { // Do something } }
What I wouldn't recommend is tryng to just update status in any kind of way.
https://developer.atlassian.com/display/JIRADEV/Performing+Issue+Operations
Look down under Transitioning an existing issue
