After the last release (we use jira cloud) it seems that we are not able to collaps single stories (and their tasks) in the active sprint.
Now we only have the option to collapse or expand all swimlanes.
Someone a suggestion to make it work again or do we have to use filters?
If anyone else sees this, this is now considered a known bug: https://jira.atlassian.com/browse/JSWCLOUD-16605.
Workarounds are to switch back to the old UI or use Expand/Collapse All Swimlanes.
We've just had users report this today as well, so I'm going to raise a support item. It appears to have been broken very recently (since Friday). The little chevron icon for expand/collapse is missing. Interestingly it is sporadically visible if you Expand All Swimlanes and then scroll but you can't click on it.
Learn more
