How to comment on existing issue using email handler
Prashant Mali
My use case is:
I am using one mail ID for creating issue. but I don't want to create comment on that existing issue using mail id.
so, Can i user different mail ID for creating comment on existing mail ID.
If possible then please tell me how to do that.
Nic Brough -Adaptavist-
December 9, 2016
When an email arrives in JIRA, the handlers will try to match up the incoming address to an existing user, and then use a default if they can't find one.
I'm not sure how you'd tell it to "use a different mail id".  I can't work out where or how you'd make the decision to use another default (you'll certainly need to find or write a new mail handler to do it, but I'm not clear on what it would actually be doing)
Prashant Mali
I am using same mail box to create ticket on both JIRA and HP SAW. it works very well.but my new requirement is to add comment to existing jira issue. but problem is that if i reply to same mail box. so it create comment to JIRA existing issue. but at the same time, It creates new tickets on jira. Is there any way to achieve this.
December 9, 2016
I don't understand that.
I can see you're using one mailbox, which is probably a bad idea, as JIRA really on;y works if it has exclusive access - it needs to read and dismiss the emails.  If JIRA is 100% in charge of doing that, your other systems could be losing email.
But I don't understand the "add comment" stuff onwards.  I guess you've set up a "create" handler, but if you need to comment as well, then you actually want a "create or comment" handler.  That will do the job fine, but your original question was about using arbitrary unknown email addresses, not create/comment.
So I'm very confused on what you're tyring to do.
Prashant Mali
Hey, I already used create or comment on existing issue handler. there is no any problem with this in JIRA at all,
but I am using one mail box(Email ID)to create issue on both JIRA and HP SAW. My only question is that, can I use different mail for adding comment on jira, so that it will not create ticket.
Or Should I go for two different mail ID's
December 9, 2016
Ok, you've made this really unnecessarily complex - why would a user want to have to remember that they have to reply to a different email address to make a comment?  But yes, you can do it.
  1.  As per the answer, you need code
  2. You'd be better off with a separate handler for the second email address, and that would avoid code
  3. I doubt your mixed mail box is working
Prashant Mali
hey Nic,
actually i am trying with single mail to create issues,comments. and its working fine.but I am using same mail id to create HP tickets.so when I replied to same mail it creates another ticket in HP SAW. and I dont want that. so tell me how to resolve this.
December 12, 2016
You'll need to change SAW so that it understands when you don't want to create the issues.
I can't help you with that - the closest experience I've got to it is getting exports when people are upgrading to JIRA.
Prashant Mali
oh, Thanks man.
It is very helpful for me.
