How to concatenate two custom field to display into one filed
Aysha.Mohammad July 27, 2022
Hi all
I need to display the values of these custom field "(PSE) From" and "(PSE) To" to Summary field
I tried below automation but it does not work . Please help
John Funk
Hi Ayesha,
Try just using issue. instead of triggerissue.
I tried already but did not work
Error
John Funk
I suspect the error is because of the parentheses used in the name of the field. Try using issue.customfield_16754 where that number is the id of the custom field instead of using the actual field names.
So, something like:
{{issue.customfield_16754}}, {{issue.customfield_15732}}
rule is successfully executed but output did not get correct
John Funk
Okay, go back to the triggerissue then and see if that solves it.
John Funk
My example above was just using made up numbers for the custom field IDs. Did you look up the actual IDs for the fields you wanted to use?
yes i used correct Ids
John Funk
Can you post your new rule?
its working now Thank you
Learn more
